Autor Wątek: Nikasil  (Przeczytany 73514 razy)
Odp: Nikasil
« Odpowiedź #15 dnia: Styczeń 21, 2011, 23:51:54 pm »
Nikasil to ceramiczna warstwa na cylyndrach, ktory Jaguar stosowal na poczatek pokolen silnikow aj-v8:
http://en.wikipedia.org/wiki/Nikasil
pomysl dobrze, ta warstwa wyrownuje minimalne nierownosci w metalu a takze ma prawie idealna
powierzchnia. niestety w niektorych warunkach (wylaczanie silnika niedogrzanego, kiepska jakosc
paliwa) potrafi sie zepsoc i spowodowac kapitalnych uszkodzen w silniku. nikasil byl stosowany do
sierpnia 2000. jaguar nie byl jedynym producentem ktory stosowal nikasil w tych czasach.
Nikasil what is it and why is it a problem.
Let me first start by saying that not all Nikasil engines have a problem. You may ask why and you will get several answers, the best I can give you is good maintenance and low sulpher fuels and the lack of short trips will extend the life of Nikasil.
Now that I confused you let me give you a link to the definition of Nikasil http://en.wikipedia.org/wiki/Nikasil and it will also inform you that this is not a problem with one car manufacture although I am doing this to inform Jaguar followers.
Now to be honest with you I am a victim of the Nikasil issue and I can tell you I was not pleased. When I purchased the car I was informed that it was well maintained by a Jaguar Dealership and I continued to do the same. However my engine failed me on starting several times and that is when I found this information on Nilasil http://www.jag-lovers.org/cjw/#0504x .
When we purchased the car I wanted to be an informed consumer. What I did find was that the tentioners fail and the water pump and the engine temperature was a concern. Very little on Nikasil .
Now you may have heard of the BlowBy test on Nikasil. . Most of us have heard of it but I must tell you that it is the best kept secret. I checked around and no one had a clue what it looked like and I was unable to find it on the internet. In fact the process was a little vague to many so I elected to try to get that information and have it available for others. I found that the BlowBy test is a real test and in fact Jaguar had the BlowBy tester manufactured. I got my hands on a video that explains the BlowBy procedure and I will make every effort to explain the process to you so you can understand. The video I received is copywrited and I am unable to post it on this page, however I will provide the resources and you can contact them and get your own copy if you wish. I asked for permission but have not received anything yet.
The BlowBy tester was developed to identify excessive bore wear. To do this the secondary breather hose is disconnected and plugged on both ends, the primary hose is then disconnected and the BlowBy tester is installed between the car and the hose. The meter will have a static reading (engine not running), then the car is started with the A/C and all other non essential turned off and it is run for 1 minute and then an additional minute. The results are calculated (I think by subtracting the static from the results) and you get the BlowBy results. Now according to the comments on the tape < 40ppm is OK! And < 30ppm is reason for concern!
FYI:
These facts apply to ALL AJ-V8’s produced between 1996 and 2001, regardless of size or application, (XK 4.0, XJ 4.0 and 3.2, S-type 4.0)
In August 2000 Jaguar replaced the Nikasil-linings with steel linings
The Nikasil cut-off date (18/08/00) is often confused with the date when low-sulphur petrol was introduced into the UK (01/01/00)
To the best of my ability the U.S. Diesel Low-sulphur date was 2006 and gasoline fuel was around 2007 (I did not want to spent a great deal of time on the sulphur issue but 1 hour later this is what I got. Not real good on the searching thing). http://www.accessmylibrary.com/artic...end-ultra.html
The risk of Nikosil failure was substantially reduced after the 01/01/00 in the UK when low-sulphur petrol was introduced, especially in new and low mileage engines.
Jaguar replaced many Nikasil engines under warranty, so a car built before the cut-off date below may possibly have steel-lined bores (check the engine number).
Nikasil - Cut-off date/number
The first steel-lined AJ-V8 came off the production line In the year 2000 on August 18th at 10.43am hence the engine number will read:
00 08 18 1043 or more precisely:
0008181043
With this piece of information it is simple to discern between a Nikasil and a steel-lined engine as all the numbers refer to the date of manufacture and any engine built before August 18th 2000 WILL have Nikasil bores!
The only way to tell if you have a Nikasil lined engine is to check the engine number, as stated in my document.
CHECK THE ENGINE NUMBER - IT IS THE ONLY SURE WAY OF KNOWING.
Engine number on V8 is under the black plastic cover, stamped on the top of the block to the right hand side of the front of the engine, near the lifting bracket.
Whether or not there is a fine line between the readings given by a compression tester and blowby tester, cannot say, but at least now you know more about the topic.
Thanks to:
http://en.wikipedia.org , http://www.jag-lovers.org , http://www.racinggreencars.com , http://www.xclusively-jaguar.co.uk , http://www.jec.org.uk/jec-new/index.php , http://www.accessmylibrary.com
Patryk
Odp: Nikasil
« Odpowiedź #16 dnia: Styczeń 21, 2011, 23:57:05 pm »
Ahmmm :) Ja mam akurat z 2000 roku auto, a czy wg vin da sie dojść czy auto jeszcze ma to ustrojstwo czy już nie? Generalnie dużo krócej dożywają te silniki?
Odp: Nikasil
« Odpowiedź #17 dnia: Styczeń 22, 2011, 00:08:38 am »
mozesz sprawdzic numer silnika. od nr 000818xxxx masz bez nikasilu. ostatni numer vin w x308 to 87871.
kilka silnikow zostaly wymieniony, wiec musisz sprawdzic numer silnika. jezeli silnik zostal wymieniony, to
posiada zielona naklejke, ale najlepiej sprawdz numer silnika.
ale nawet jezeli masz, to nie ma paniki. wszystko zalezy jak traktujesz auteczko i jaki paliwo mu lejesz. unikaj
kiepska wache i nie wylacz silnik po krotkich jazdach. poczytaj troche, watek dotyczy xk, ale z takim samym
silnikiem:
http://jaguarclubpoland.net/forum/index.php?topic=1148.0
Offline xjscabrio
  • Wiadomości: 160
Odp: Nikasil
« Odpowiedź #18 dnia: Maj 14, 2011, 23:36:18 pm »
gdzie jest na silniku nabity numer silnika?
jak sprawdzic czy auto ma silnik z nikasilem bez numeru silnika? czy optycznie czyms sie rozni?
czy silnikw xjr i w super v8 w tym samym okresie byly zmienione?
XJR-S ,XJR XJ40,X358
Viking
Odp: Nikasil
« Odpowiedź #19 dnia: Maj 15, 2011, 15:45:37 pm »
 Powłoka nikasilowa była nakładana na gładzie cylindrów w celu zminimalizowania tarcia cylinder-tłok w blokach z aluminium. Sama powłoka nikasilu ma ogromną odporność na ścieranie i żywotnością przewyższa pozostałe elementy silnika, więc nawet zimny start i zawieszanie się komputera nie były aż takie mordercze dla silnika. Nie wiem kto rozpuszcza opinie ze po 200000km nikasil zaczyna odpadać. Nie znalazłem nigdzie wyników badań (oprócz plotek na forach) które by to potwierdziły. Drugim zagrożeniem dla nikasilu były związki siarki zawarte w paliwie, które rozpuszczały powłoke. Na ten problem nie było już żadnego ratunku. Rzecz w tym że dotyczył on wyłącznie rynku amerykańskiego, brytyjskiego i irlandzkiego. W kontynentalnej Europie, już w latach produkcji x308, paliwo było odsiarczone (prawnie ustalone) a więc niegroźne dla nikasilu. W UK i Irlandii przepisy odnośnie siarki w paliwie, zmieniły się około 2000r. Jak było w stanach i Kanadzie, to tego niestety nie wiem. Do tego nikasil był stosowany nie tylko przez jaguara ale też przez ferrari, maserati (wszystkie silniki biturbo), porsche (model turbo), bmw (v8 z lat 90), więc była to dosyć zaawansowana technologia w tamtych latach.
Więc jesli ktoś ma pewność że auto pochodzi z Europy (nie przekładka z UK) i nie wykazuje żadnych problemów przy odpalaniu, to uważam że można śmiało kupować taki egzemplarz a użytkownik szybko zapomni że ma coś takiego w silniku jak NIKASIL.
Odp: Nikasil
« Odpowiedź #20 dnia: Maj 15, 2011, 16:13:25 pm »
xjscabrio, numer silnika znajdziesz kolo odbudowej termostatu. silniki z wygladu niczym sie nie roznia, jedyna
mozliwosc, aby sie dowiedziec czy silnik ma nikasil, to numer silnika.
to co viking napisal, jest w pelni prawda  :-super
Offline xjscabrio
  • Wiadomości: 160
Odp: Nikasil
« Odpowiedź #21 dnia: Maj 16, 2011, 22:56:22 pm »
a czy auto kotre ma taki ostatnie 6 zankow vin "F22142" ma silnik z nikasilem?
czy mozna to tak ustalic?
z gory dziekuje za inofrmacje
Odp: Nikasil
« Odpowiedź #22 dnia: Maj 17, 2011, 01:05:03 am »
hej, auto z takim numerem vin nie ma nikasilu.
wszystkie samochody, ktory mieli silniki z nikasilem maja koncowke vin z siedmiu numerow. jezeli koncowka ma
na poczatku literke (F albo G dla XJ oraz A dla XK), to samochod nie ma nikasil.
Offline xjscabrio
  • Wiadomości: 160
Odp: Nikasil
« Odpowiedź #23 dnia: Maj 17, 2011, 09:23:04 am »
rozumiem . dziekuje bardzo
DJ Krystian
Odp: Nikasil
« Odpowiedź #24 dnia: Grudzień 06, 2011, 16:44:55 pm »
Mniej więcej wiadomo, że Nikasil to cienka powłoka wewnętrznej części cylindra, która jest lepsza od żeliwnej tulei, ale gdy ulegnie awarii...
Ponadto wiadomo, że poprawia osiągi oraz trwałość i... tu wiedza się kończy. W poniższym tekście podzielę się z Wami tym, co udało się ustalić na bazie naukowych publikacji, broszur informacyjnych oraz innych materiałów.
Geneza, czyli kto to wymyślił i dlaczego?
Na początek warto zaznaczyć, że nie ma jednej, wyłącznej nazwy na metodę powlekania niklem wewnętrznej części cylindra. Pierwszą firmą, która opatentowała Nikasil w 1967 roku, był niemiecki koncern motoryzacyjny Mahle. Inne firmy, które opracowały własne metody nieco później, to Nicom (U.S. Chrome Corp. of Wisconsin), NSC (Millennium Technologies), Nihon Parker, Polaris Fuji oraz inni. Stąd zapewne bierze się wiele sposobów pisania nazwy tej samej technologii, np. nikasil, nicasil, NiCS lub NiCaSil.
Zanim przejdę do opisania składu oraz sposobu powlekania nikasilem, przyjrzyjmy się powodom, dla których powstał. Konstruktorów silników samochodowych, motocyklowych i nie tylko (szczególnie lotniczych) od dawna nurtuje problem ciężaru, osiągów i trwałości. Z jednej strony kadłuby jednostek napędowych (w tym cylindry) wykonane z żeliwa są bardzo ciężkie i słabo przewodzą ciepło (problem z chłodzeniem), ale za to są tanie, trwałe, posiadają bardzo dobre właściwości ślizgowe i zdolność wiązania oleju. Z drugiej strony aluminiowe konstrukcje są znacznie lżejsze i lepiej przewodzą ciepło (łatwiej je ochłodzić), ale są zbyt miękkie, nietrwałe i droższe w produkcji.
Dlatego inżynierowie wpadli na pomysł wbijania (wprasowywania) żeliwnych tulei o grubości kilku milimetrów do cylindrów. Po dziś dzień w pojazdach cywilnych jest to najpopularniejszy sposób konstrukcji cylindrów. Dzieje się tak głównie z powodu niskich kosztów i łatwości produkcji. W sporcie to jednak nie wystarcza. Tu liczą się osiągi i walka o każdy koń mechaniczny, a w efekcie o każdy ułamek sekundy podczas wyścigu! Nawet kilkumilimetrowa żeliwna tuleja, wbita do cylindra, to dodatkowy ciężar oraz spadek wydajności chłodzenia.
Podobno pierwsze próby z powłokami chromowymi przeprowadzano w trakcie II wojny światowej w lotnictwie, gdzie waga silnika ma kluczowe znaczenie. Jednak dopiero pod koniec lat sześćdziesiątych pojawił się lekki, wysokoobrotowy silnik benzynowy Wankla (z wirującym tłokiem) oraz szereg silników sportowych, które potrzebowały cienkiej i twardej powłoki. Eksperymenty z niklem zaowocowały powstaniem nikasilu, którego zalety szybko dostrzegli znani producenci pojazdów sportowych, m.in. BWM, Porsche, Jaguar, Ferrari, niemal wszyscy znaczący producenci motorówek, skuterów wodnych i śnieżnych, quadów oraz motocykli.
Przy okazji warto wspomnieć, że równolegle były i nadal są rozwijane alternatywne technologie oparte o inny metal (dokładniej o stopy metali, gdzie jeden zwykle jest materiałem wiążącym, a pozostałe to dodatki zapewniające lepszą twardość oraz utrzymywanie oleju) jako materiał użyty do utwardzenia wewnętrznej części aluminiowych cylindrów. Według terminologii Mahle są to Cromal (nośnikiem jest chrom, stosowany głównie do małych silników dwu- i czterosuwowych), Ferral (płomieniowe pokrycie cylindra stopem żelaza), Silumal (hipereutektyczny stop aluminium, krzemu, miedzi oraz magnezu) oraz technologie kompozytowe, jak Biral czy Lokasil (żeliwne tuleje są fabrycznie zalewane aluminium formując cylinder).
Utwardzanie wewnętrznej części cylindra nie tylko zwiększa odporność na ścieranie, ale także poprawia sztywność, wpływa na lepsze utrzymanie oleju (tzw. film olejowy, czyli cienka warstwa oleju osadza się na ściankach, szczególnie w mikro zagłębianiach powstałych w wyniku honowania), ale przede wszystkich zwiększa przewodnictwo cieplne. To pozwala szybciej schładzać komorę spalania od 10% (technologie kompozytowe) do 15% (nikasil), a nawet 20% (aluminium bez żadnych powłok). Daje to konstruktorom możliwość zwiększenia prędkości obrotowej silnika, a tym samym mocy.
Z czego robi się Nikasil i jak nanosi na cylinder?
To jest najpilniej strzeżona tajemnica firm posługujących się technologiami opartymi o nikiel i dodatki. Szczegóły procesu technologicznego nie są udostępniane nikomu z zewnątrz.
Nikasil (z ang. nickel silicone carbide, czyli związek niklu, krzemu oraz węglika) to bardzo twardy stop metali, który w procesie galwanizacji (elektrolityczne nakładanie cienkiej warstwy metalu na inny metal) jest nakładany na wnętrze cylindra. W wyniku elektrolizy (traktowanie prądem cieczy o określonym składzie chemicznym) rozpuszczony nikiel stanowi podstawową substancję wypełniającą oraz wiążącą drobiny węglika krzemu. Te ostanie stanowią tylko ok. 4% całości nikasilu. Wielkość tych drobin, w zależności od technologi, waha się od 0,0025 do 0,004 mm (2,5 do 4 mikronów, mikron to jedna tysięczna milimetra). Nikasil jest nakładany przez zanurzanie w cieczy. Im dłuższa jest kąpiel, tym grubsza warstwa może zostać nałożona. Przyjmuje się, że jest to ok. 0,01 mm na 15 min. Oczywiście proces jest bardziej skomplikowany, a sam cylinder przed kąpielą i pokryciem musi przejść kilka faz czyszczenia oraz zabezpieczenia części nie podlegających powlekaniu (kanały dolotowe i wylotowe, otwory technologiczne, kanały dla cieczy chłodzącej, kanały olejowe czy miejsca mocowania). Jedna z faz czyszczenia to zanurzanie w żrącym roztworze.
Związek niklu, krzemu i węglika jest od trzech do dziesięciu razy mocniejszy od innych powłok. Świadczyć o tym może fakt, że do końcowej obróbki, tzw. honowania (charakterystycznej jodełki widocznej we wnętrzu cylindra), używa się wyłącznie diamentowych szczotek. Ten proces przeprowadza się po to, by film olejowy lepiej utrzymywał się na powierzchni tarcia z tłokiem oraz w celu owalizacji i osiowania cylindra (musi być idealnie okrągły i prosty na całej długości). Czołowe firmy robią to z dokładnością ok. 0,0002–0,0005 mm. Nikasil może być nakładany dowolną ilość razy.
Trwałość nikasilu jest niebywała. Spotyka się z opinią, że nikasil mocniej wiąże się z aluminium niż aluminium z aluminium. Gdy patrzymy na tzw. odprysk nikasilu, to nie jest to zwykle sam płat nikasilu, ale pod nim jest cieka warstwa aluminium, które się z nim związało. Jest odporny na wysokie temperatury oraz ciśnienie przekraczające 17 atmosfer.
Jak użytkować cylinder z nikasilem?
W zasadzie nie ma specjalnych zaleceń. Bywały awarie samochodów z uwagi na dużą zawartość siarki powstałej w wyniku spalania benzyny z dużą zawartością ołowiu. Od czasu wprowadzenia paliw bezołowiowych ten problem został wyeliminowany. Niemniej jednak warto pamiętać, że nikasil lubi dobre paliwo, zresztą jak każdy silnik. Zawsze należy sprawdzić, jaki rodzaj paliwa oraz jaką liczbę oktanową zaleca producent. Pamiętajcie, że w cylindrze zachodzą ekstremalne reakcje chemiczne i termobaryczne, co oznacza, że w procesie spalania pojawia się wysoka temperatura, wysokie ciśnienie oraz substancje żrące, więc warto pamiętać o okresowych przeglądach i nie oszczędzać na podzespołach silnika, szczególnie w mechanizmach tłokowo-korbowym oraz rozrządu.
bidiniusz
Odp: Nikasil
« Odpowiedź #25 dnia: Styczeń 17, 2012, 16:05:45 pm »
Czyli SAJAA14M31LF34843 jest bez Nikasilu...
Ale czy to nie jest tak, że jednak zadbany Nikasil to pozytywny element silnika? Czym go zastąpiono, bo przecież nie żeliwem...
Krzysio7890
Odp: Nikasil
« Odpowiedź #26 dnia: Styczeń 30, 2013, 13:26:04 pm »
Miałem BMW 740 e38 z nikasilem a teraz mam xj8 od prawie 2 lat, również z nikasilem. Przebieg 245 tyś km i nic się nie dzieje. Nie uważam, że należy się go bać. Z tego co wiem to w BMW np. zastąpiono go później alusilem.
semo
Odp: Nikasil
« Odpowiedź #27 dnia: Luty 01, 2015, 09:24:06 am »
DJ Krystian - dzięki.
Dużo się dowiedziałem. A że rozważam kupno X300 lub X308 który ma zostać u mnie na zawsze, to taka wiedza jest cenna.
Jaguar Parts
Odp: Nikasil
« Odpowiedź #28 dnia: Luty 01, 2015, 09:57:31 am »
Ja miałem BMW z nikasilem i szlag go trafił. Kupiłem XJ8 też z nikasilem, a właściwie już bez niego. Oba auta były serwisowane regularnie. Wydaje mi się, że z nikasilem jest jak z silnikiem 2.7d. Może szybko paść, ale nie musi. Jednak jest to podwyższone ryzyko.
Offline Jaguar Wroc³aw
  • Wiadomości: 462
Odp: Nikasil
« Odpowiedź #29 dnia: Luty 02, 2015, 23:09:00 pm »
ostatnio sprzedawałem Porsche Cayenne Turbo S i też miał nikasil, zdziwiłem się ale to podobno norma w tej marce...
