Panel, reperaturka tył, prawa strona do Jaguar XJ40, XJ12, XJ6, X300, X308. Panele pasują idealnie jak widać na fotkach.
Do modeli 300, 308 należy obciąc koniec panelu około 15 cm jak w opisie poniżej.
This rear wheel arch outer panel will fit the following Jaguar XJ40, X300, and X308 models:
XJ6 & XJ12 - XJ40 (2.9L, 3.2L, 3.6L and 4.0L models)
VIN range: From 500001 to 667828
X300
VIN range: From 720125 to 812255
X308
VIN range: From 812317 to F59525
Please Note: For this part to fit the X300 and the X308 models, it will need slight modification. You will need to cut off around 6 inches (150mm) of the rear section of the panel in order it will fit where the rear bumper (fender) meets the wheel arch.
The arch will NOT need any modification to fit the XJ40 models.
Marcin 604 400 929.
