Autor Wątek: Zmiana płynu chłodniczego  (Przeczytany 2655 razy)
Offline mbolo
  • Wiadomości: 206
« dnia: Wrzesień 05, 2018, 20:21:48 pm »
Witam. Gdzie znajdę korek do spuszczania płynu z układu chłodzącego. Jak najlepiej wyczyścić układ ?
Offline Alef Zero
  • Wiadomości: 67
  • xj8 2004
Odp: Zmiana płynu chłodniczego
« Odpowiedź #1 dnia: Wrzesień 05, 2018, 23:16:44 pm »
Procedura płukania zaczerpnięta z manuala:
Cooling System Backflushing
CAUTION: The heater core must be backflushed separately from the engine
cooling system to prevent the engine cooling system particles from clogging the heater
core tubes and reducing (or eliminating) coolant flow through the heater core. All engine
cooling system flushing and backflushing procedures must include a separate
backflushing of the heater core after the flushing or backflushing of the engine cooling
system.
CAUTION: Heater core internal pressure must not exceed 100 kPa (14.5 psi).
Failure to follow this instruction may cause damage to the heater core.
NOTE:
Cooling system backflushing should be carried out before the cooling system components
are installed after the cooling system flushing procedure.
1. Disconnect the heater outlet coolant hose from the engine and connect the heater hose to a
suitable hose pipe.
2. Disconnect the heater inlet coolant hose from the engine and allow the coolant to drain into
a suitable container.
3. Turn the water supply valve to the hose ON and allow water pressure to flow through the
heater core.
4. Allow water pressure to flow through the heater core for approximately five minutes.
5. Turn the water supply valve to the hose OFF and disconnect the hose pipe from the heater
hose.
6. Connect the heater inlet coolant hose to the engine.
7. Connect the heater outlet coolant hose to the engine.
8. Fill the cooling system as described using a 50% mixture of Jaguar Premium Cooling
System Fluid, or equivalent meeting Jaguar specification WSS M97B44-D and 50% distilled
water.
9. Test the system for correct heater performance with the specified engine cooling system
conditions.
Radiator Backflushing
1. Remove the radiator.
2. Invert the radiator.
3. Connect a suitable hose pipe to the lower coolant hose connection of the radiator.
4. Turn the water supply valve to the hose ON and allow water pressure to flow through the
radiator.
5. Allow water pressure to flow through the radiator for approximately five minutes.
6. Turn the water supply valve to the hose OFF and disconnect the hose pipe from the
radiator.
7. Allow the coolant to drain from the radiator.
8. Install the radiator.
Engine Backflushing
1. Remove the thermostat before backflushing the engine.
2. Position the high-pressure water hose into the engine through the engine return and
backflush the engine.
3. Connect a suitable hose pipe to the upper coolant hose connection of the engine.
engine.
5. Allow water pressure to flow through the engine for approximately five minutes.
6. Turn the water supply valve to the hose OFF and disconnect the hose pipe from the upper
7. Connect the upper coolant hose to the engine.
System Fluid or equivalent, meeting Jaguar specification WSS M97B44-D and 50% distilled
water.
Offline mbolo
  • Wiadomości: 206
« Odpowiedź #2 dnia: Wrzesień 06, 2018, 13:07:12 pm »
Coś nie co rozjaśniło się. Rozumiem że mogę płukać zwykła wodą ?   Jaki polecacie płyn zna zalanie układu ?
Offline Boodzio2
  • Wiadomości: 1.073
« Odpowiedź #3 dnia: Wrzesień 07, 2018, 19:05:58 pm »
Korek spustowy jest stojąc przed autem w prawym dolnym rogu chłodnicy.
Offline Alef Zero
  • Wiadomości: 67
  • xj8 2004
« Odpowiedź #4 dnia: Wrzesień 08, 2018, 09:15:10 am »
Tak, zwykłą wodą.
Ja zalałem potem koncentratem g12+ czerwony + woda destylowana
Offline mbolo
  • Wiadomości: 206
« Odpowiedź #5 dnia: Wrzesień 10, 2018, 09:08:32 am »
Koncentrat rozumiem . Czerwony to barwnik ? . Ile wchodzi płynu jak rozcieńczasz
Offline Alef Zero
  • Wiadomości: 67
  • xj8 2004
« Odpowiedź #6 dnia: Wrzesień 10, 2018, 12:24:20 pm »
na nasze warunki klimatyczne 50:50
« Odpowiedź #7 dnia: Wrzesień 10, 2018, 19:03:42 pm »
Kup sobie gotowy płyn. Zazwyczaj gotowce są od -32 do -38 stopni co w zupełności wystarcza.
