Autor Wątek: bezpiecznki i przekazniki  (Przeczytany 61896 razy)
sebus34
« dnia: Styczeń 02, 2010, 19:07:28 pm »
potrzebuje rozpiske  bezpiecznikow i przekaznikow do kota z 2001r.
Odp: bezpiecznki i przekazniki
« Odpowiedź #1 dnia: Styczeń 02, 2010, 19:51:30 pm »
Engine compartment fuse box - fuses
Fuse Fuse Rating Colour Circuit
No. Type (amps)
F1 Cartridge 20 Blue Dip beam, High Intensity Discharge (HID) light relay.
F2 Cartridge 50 Red Ignition relay feed.
F3 Cartridge 60 Yellow ABS.
F4 Cartridge 30 Pink Rear window heater/heated mirrors relay.
F5 Cartridge 30 Pink Automatic transmission control module relay.
F6 Cartridge 30 Pink Heater blower relay.
F7 Cartridge 50 Red Power supply to passenger compartment fuse box.
F8 Cartridge 80 Black Blower module.
F9 Cartridge 50 Red Engine management system power relay.
F10 Cartridge 20 Blue Headlight power wash pump relay.
F11 Mini Not used.
F12 Mini Not used.
F13 Mini 30 Green Heated front screen right-hand side.
F14 Mini Not used.
F15 Mini 30 Green Heated front screen left-hand side.
F16 Mini 20 Yellow Left-hand dip beam, day time running lights, autolights.
F17 Mini 20 Yellow Right-hand dip beam, HID lights.
F18 Mini 20 Yellow Throttle motor supply.
F19 Mini 15 Blue Screenwash pump, rain sensing system.
F20 Mini 5 Tan Navigation display.
F21 Mini 15 Blue Side (Parking) lights.
F22 Mini 20 Yellow Accessories relay.
F23 Mini 10 Red Air conditioning compressor clutch.
F24 Mini 15 Blue Door lock power.
F25 Mini 15 Blue Direction indicators (GEM).
F26 Mini 15 Blue Horns.
F27 Mini 10 Red Automatic transmission control module, transit relay.
F28 Mini 15 Blue Ignition switch.
F29 Mini 30 Green Starter motor solenoid.
F30 Mini 30 Green Accessory sockets.
F31 Mini 10 Red Engine management relay coil.
F32 Mini 5 Tan Engine management control.
F33 Not used.
F34 Diode D3 Not used.
F35 Diode D2 Engine management control relay diode.
F36 Mini 10 Red Canister purge valve, airflow meter, throttle motor relay, power wash relay, air conditioning relay.
F37 Mini 15 Blue Engine management system, blower speed controller, road speed sensor (if fitted).
F38 Mini 30 Green Oxygen sensor heaters A.
F39 Mini 5 Tan Variable intake valves.
F40 Mini 15 Blue Automatic transmission control module.
F41 Mini 10 Red Injectors.
F42 Mini 30 Green Oxygen sensor heaters B.
Passenger compartment fuse box - fuses
No. Type (amps)
F60 Mini 20 Yellow Power windows left-hand.
F61 Mini 20 Yellow Power windows right-hand.
F62 Mini 7.5 Brown Rear fog lights.
F63 Mini 7.5 Brown Right-hand - front side light, side markers, rear tail lights.
F64 Mini 7.5 Brown Left-hand - front side light, side markers, rear tail lights.
F65 Mini Not used.
F66 Mini 30 Green Left-hand power seat switches, heater module, lumbar pump.
F67 Mini 5 Tan Battery back-up sounder, transit relay, HID/dip relay, automatic transmission control module.
F68 Mini 15 Blue Cigar lighter.
F69 Mini 7.5 Brown Telematics display, In-car entertainment head unit, antenna module, navigation module, VICS (Japan), parking aid, amplifier premium 1 system, phone handset, phone power supply module, instrument cluster, PATS module.
F70 Mini 30 Green Right-hand power seat switches, heater module, lumbar pump.
F71 Mini 15 Blue VICS (Japan), telephone transceiver, telephone handset.
F72 Mini 15 Blue Radio head unit, CD player, navigation electronic control module, Jaguar diagnostic connector/OBDII connector.
F73 Mini 15 Blue Sunroof unit/module.
F74 Mini 15 Blue Instrument cluster, Premium ICE amplifier unit.
F75 Mini 7.5 Brown Mirror fold back module, battery back-up sounder, air conditioning ECU.
F76 Mini Not used.
F77 Mini 7.5 Brown Left-hand and right-hand heated seats modules.
F78 Mini 5 Tan Phone power supply.
F79 Mini 10 Red Automatic transmission only: Reverse lights, reverse light switch, reverse park aid, electrochromic mirror, instrument cluster.
F80 Mini 7.5 Brown Park interlock, heater switch, OBDII, blower relay.
F81 Mini 20 Yellow Fuel pump control module.
F82 Mini 10 Red Variable power steering, alternator.
Manual transmission only: Reverse lights, reverse light switch reverse park aid, electrochromic mirror, instrument cluster.
F83 Mini 15 Blue Not used.
F84 Mini 5 Tan Instrument cluster, passenger airbag fascia light, seat weight sensor.
F85 Mini 7.5 Brown Right-hand high beam light.
F86 Mini 7.5 Brown Left-hand high beam light.
F87 Mini 15 Blue Front fog lights, master light switch.
F88 Mini Not used.
F89 Mini Not used.
F90 Mini 7.5 Brown Stop lights, cruise control.
F91 Mini 10 Red Sunroof, electrochromic mirror, power windows, power mirrors.
F92 Mini 10 Red Manual transmission cruise control clutch switch, ignition coils, automatic transmission rotary switch.
F93 Mini 30 Green Windscreen wipers.
F94 Mini 20 Yellow HID module.
F95 Mini 10 Red Airbag restraints module.
F96 Mini 7.5 Brown ABS module.
F97 Mini 7.5 Brown Glove compartment light, instrument cluster lights, licence plate lights.
F98 Mini 10 Red Mirror heaters.
F99 Mini 10 Red Luggage compartment light, footwell lights, puddle lights, vanity mirror lights, interior lights, aircon control unit, roof console unit.
Offline muttley
  • Wiadomości: 227
« Odpowiedź #2 dnia: Grudzień 28, 2010, 12:03:49 pm »
U mnie bezpieczniki wygladają trochę inaczej niż na prezentowanym wyżej diagramie. Może ktoś z was pomógłby mi znaleźć bezpiecznik odpowiedzialny za spryskiwacze?
http://www.jaguarforums.com/forum/showthread.php?p=267275
TYGRYS3
« Odpowiedź #3 dnia: Grudzień 28, 2010, 14:50:07 pm »
BlackV6
« Odpowiedź #4 dnia: Czerwiec 10, 2011, 11:37:39 am »
Tak dla pewności za światła przeciwmgielne jest odpowiedzialny bezpiecznik F2 50 A ? bo coś się dzisiaj kocur źle przebudził z rana i nie świecą wr jakie jest prawdopodobieństwo przepalenia się dwóch na raz ? i jakie tam są ?
Offline bodi
  • Wiadomości: 605
« Odpowiedź #5 dnia: Luty 02, 2014, 16:19:51 pm »
Tam idą takie same jak wszędzie czyli H1
w mijania, drogowych i halogenach są H1
a jeżeli chodzi o prawdopodobieństwo to mi światła mijania skończyły się kilka miesięcy temu jednego dnia po obu stronach (nie potrafię określić czy w tym samym momencie, bo było to w dzień, ale na 100% w ciągu jednego dnia)
Jeżeli chodzi o bezpieczniki, to są różne skrzynki bezpieczników i powinieneś zajrzeć do książki auta (jeżeli takową posiadasz) lub na forum są podane różne układy i powinieneś znaleźć, który to bezpiecznik
Fiorino
« Odpowiedź #6 dnia: Listopad 28, 2015, 07:44:36 am »
Witam, a czy ktoś mógłby mi powiedziec który bezpiecznik odpowiada za drugie gniazdko zapalniczki w bagażniku wersji kombi?
Te pod radiem działa, a wygląda na to, że wszystkie bezpieczniki pod kolumną kierowniczą są wporządku.
Ł.
Offline voitec
  • Wiadomości: 876
« Odpowiedź #7 dnia: Maj 27, 2016, 21:09:23 pm »
Napiszcie proszę jaki bezpiecznik będzie odpowiadać za poprawne działanie zapalniczki, x type 2007 2,2D - wiem,że temat był poruszany ale były różne układy bezpieczników stąd moje pytanie
Poszukaj: http://www.jagrepair.com/images/AutoRepairPhotos/CarPDFFiles/JaguarXType/2007XTypeElectrical.pdf
X-type 3.0 Estate '05 LPG
X-type 3.0 Sedan '01 LPG
Fighter8888
« Odpowiedź #8 dnia: Maj 07, 2017, 17:30:51 pm »
Hej który bezpiecznik odpowiada za spryskiwacze nie moge dojsc ,wycieraczki działają
2.1 v6
Od telefonu motorola tez jest bezpieznik?
Offline Shimon
  • Wiadomości: 1
« Odpowiedź #9 dnia: Listopad 06, 2018, 18:43:23 pm »
Czy w Jaguarze X-Type za światła przeciwmgielne przednie jest odpowiedzialny indywidualny bezpiecznik ? Bo wszystko świeci oprócz przednich halogenów :(
Nie jest normalne że w dwóch naraz żarówki się  spaliły ....
Offline Ardenale
  • Wiadomości: 17
« Odpowiedź #10 dnia: Listopad 07, 2018, 14:12:43 pm »
Witam.
Mam pytanie.
Wie ktoś może czy jest oddzielny bezpiecznik odpowiedzialny za działanie spryskiwaczy reflektorów w X-sie?
Jeśli tak to byłbym wdzięczny za informację. Pozdrawiam.
JAGUAR/X-TYPE/3.0/2006R/BLACK SPORT.
Offline voitec
  • Wiadomości: 876
« Odpowiedź #11 dnia: Listopad 07, 2018, 18:27:02 pm »
Tak, jest oddzielny.
Offline Ardenale
  • Wiadomości: 17
« Odpowiedź #12 dnia: Listopad 09, 2018, 15:33:38 pm »
A mamy wiedzę który to bezpiecznik?
Offline voitec
  • Wiadomości: 876
« Odpowiedź #13 dnia: Listopad 09, 2018, 19:47:23 pm »
Mamy :) Tam z 3-4 posty wyżej masz link wrzucony przeze mnie. Otwórz go sobie, wpisz w szukajce powerwash pump i znajdziesz na schemacie, który bezpiecznik (F) jest przed pompką.
Offline Ardenale
  • Wiadomości: 17
« Odpowiedź #14 dnia: Listopad 13, 2018, 15:21:21 pm »
Dziękuję za informację. Znalazłem w schemacie to o co mi chodziło.
Bezpiecznik a raczej przekaźnik odpowiedzialny za działanie spryskiwaczy reflektorów w X-sie to R8.
